Old 02-03-2011, 10:49 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Default aerobatic fuel squashing
With 15 Us gallons for each tank, I play some aileron rolls.
Every time I start my full aileron movement I feel a 'double time' movement in the same side of the roll (I hope that is the fuel forced into a quick movement).
A slow motion roll give me no problem.
Any idea or experience to share with me ?
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 02-03-2011, 11:02 AM
DEWATSON DEWATSON is offline
Does it feel like aileron bump?
Old 02-03-2011, 11:21 AM
N733JJ N733JJ is offline
Default Aileron stall
This is pretty common with full deflection ailerons in RV's. I believe it is actually a buffet from aileron stall but I haven't tufted it to be 1000% sure.
I bet Kevin Horton can come up with a proper explaination.
Scott A. Jordan
Toobuilder's Avatar
First thing I thought of too. The first time I did a full deflection roll with the -8 I felt the burble too.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-03-2011, 11:29 AM
Mel's Avatar
Mel Mel is offline
Default Yep!
It's aileron buffet. Try 1/2-3/4 deflection. Much smoother. And almost as fast.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-03-2011, 03:35 PM
mike newall's Avatar
mike newall mike newall is offline
Yep - watch the aileron - it is interesting !!!!
Old 02-04-2011, 02:30 AM
flyvans.com flyvans.com is offline
Default aileron buffet
Definitely nothing to do with fuel.
And happens in all 2-seat rv's that i've flown, 6,7,8.
it's definitely aerodynamic from the ailerons themselves, however i'm not sure whether it's caused by the up or down aileron...
also, we found the best / most agile / good control feel speed is around 120kt, right near the official maneuvering speed of 123kts.
so if we want to do some sightseeing / orbits and such, we reduce to 110-120kts first, plus you get more time to look at the things on ground.
we also start rolls mostly around 120, where that buffet is not so pronounced.
anything above is just for cruising, descent and loops (140kts).
rgds, bernie
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
