Old 02-02-2011, 09:01 PM
aarvig's Avatar
aarvig aarvig is offline
Default What size drill bit for a #6 screw?
I am dimpling (#6) the trim reinforcement plate on the left elevator of my RV-9A. The plans call to dimple for a #6 screw. What drill size should I use to match drill these holes and can I assume that a #6 screw uses a #6 dimple die?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 02-02-2011, 10:05 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
#28 drill bit for a #6
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 02-02-2011, 10:10 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Get a catalog from Cleaveland Tool. They have a great pull out poster with all the rivet, screw, bolt and drill sizes that you can put on your shop wall.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-03-2011, 01:53 AM
sf3543 sf3543 is offline
For a 6-32 screw, a #27 or #28 drill will provide close tolerance for the screw to fit through. A #35 or #36 drill is used if you are going to tap threads for a 6-32 screw. Here's a chart example.. http://www.physics.ncsu.edu/pearl/Tap_Drill_Chart.html
There is a special dimple die for a #6 screw that you can get from Avery or Cleaveland, etc. http://www.cleavelandtoolstore.com/p...number=DIE5096 for an example from Cleaveland.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 02-03-2011, 07:16 AM
aarvig's Avatar
Default That was easy!!
Thanks for all the help guys. Steve, I printed off the charts you provided the link to as well as located the chart in the cleaveland tool catalog. They will do the job.
Thanks again!
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
