Old 04-03-2006, 10:57 AM
dwilson dwilson is offline
Default Glare shield edge protection
I know this was addressed a while back, but I cannot locate the thread. What works for protecting the aft edge of the glare shield? O better yet protects the pilot from the aft edge of the glare shield if his head gets too close?
Duane
Old 04-03-2006, 11:28 AM
mark manda's Avatar
mark manda mark manda is offline
Most guys use the push on trim. It snaps on and has a molded stitched look to it.
I found it in grey at the local Fabric shop that has an automotive section with all kinds of beads etc.
I think Cleveland sells it. Probably $3 a ft. approx.
lots of good picts in the 7 show us your panel thread. Or actually any of the show us your panel threads.
Old 04-03-2006, 12:53 PM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
I got some 1/2" rubber hose from a local auto parts supplier, split it lengthwise, and pushed it on. It was cheap, looks great, and is cushion-ey enough that it will do the trick.
Cheers
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
Old 04-03-2006, 04:42 PM
Harvey's Avatar
Harvey Harvey is offline
Location: I live on an airpark in South East Queensland, Australia
Default Glare Shield Edge
I chose to use a length of the aluminum brake line, slit length-ways and pushed over the glare shield edge. I really didn't think that it would be a permanent solution, but it looks good and probably as effective as any rubber hose version.
Martin in Oz
Old 04-03-2006, 04:55 PM
dan's Avatar
dan dan is offline
www.mcmaster.com
p/n 8451A22
$0.41 per foot (let's just say, um, "affordable")
Dan Checkoway RV-7
Old 04-03-2006, 04:57 PM
painless painless is offline
The edging that Dan illustrated is what I used. Stuff is easy to work with, cheap and looks great.
Thanks again for sharing that Dan.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 04-03-2006, 04:58 PM
Default That's it!
Thanks Dan,
I looked on their site but didn't know what to call the stuff and came up empty.
Duane
Old 04-03-2006, 05:49 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Specialty paint stores
Any specialty auto paint stores will have a variety of trim available. I got some stuff like Dan illustrated that has a glue bead in the middle. It looks great is relatively soft and easy to install.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 04-03-2006, 08:20 PM
RV10Pilot RV10Pilot is offline
Originally Posted by dwilson
Thanks Dan,
Duane
Just put the part number 8451A22 in the white field under the "Find Products" tab, select the Find button and brings you right to page 3537 of the catalog where you will find the vinyl edge trim.
Larry
http://lrosen.nerv10.com
Old 04-03-2006, 08:52 PM
Default Aluminum Tube and Thin Black Rubber Tubing
If you have an accident that edge is going to cut through softer stuff and plastic will turn to granules over time. I split 3/8" aluminum tubing and pressed it over the edge, then I split some 3/8" rubber tubing and glued it over the aluminum tubing.
Bob Axsom
