01-31-2011, 02:25 PM
Condensation on Airplane
Here in the Northwest as most of you may know we get weeks and weeks of high humidity, gloomy, overcast and rainy weather. During this time I can go out to the hanger and have condensation laying on the wings, dripping off the fuselage and coating a large amount of the airplane. Unfortunately like most public use airports around here the hangers are not heated, have gaps around the sliding doors and are open to other adjoining hangers in the rafter space. I'm sure all this condensation laying on the airplane can't be a good thing. Heating an uninsulated hanger with a single 120 volt outlet that is open to adjoining hangers isn't an option. Some type of dehumidifier is probably also not an option with the volume of space. I thought about covering the airplane but that may just trap the moisture. So does anyone have any ideas on how to reduce or eliminate this condensation?
Mark - Forest Grove, OR (Homebase KHIO)
Flying RV-9A N962MC
EAA Tech Advisor - Ham AI7MC
01-31-2011, 02:29 PM
I know here in Arkansas I insulated the ceiling in our barn to stop the condensation from dripping all over the hay. In the winter when the sun hits that metal roof it rains inside the barn. Other than that I'm not sure what you could do.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
01-31-2011, 02:36 PM
Around here condensation happens because the cool temperature of the airframe mass lags behind a rise in air temperature, most often when warm moist air comes up off the Gulf. Many owners run a cheap box fan (on low or medium) to circulate air around the airframe and thus keep air and airframe temps the same. It works.
Dan Horton
RV-8 SS
Barrett IO-390
01-31-2011, 03:10 PM
I keep one of these on in my baggage area all the time.
http://www.westmarine.com/webapp/wcs...oductId=100586
It keeps things dry on the inside and condensation off most of the fuselage.
I haven't figured out a solution for the rest of the airframe, though.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 ( blog)
Paine Field (KPAE)
EAA Chapter 1440
01-31-2011, 03:46 PM
Vapor Barrier ?
Hey Rob.. I have been thinking about your specific issue with the water soaking up through the concrete, and while having no direct experience... Maybe you can buy some thin plastic painters tarp from home depot. Super cheap stuff that will cover lots of area and just lay it on the floor under the plane (not over it) ;-). Sort of like a vapor barrier over the concrete. Might be worth a try if you can't find anything else and if it is the water coming up from beneath that is causing your problem.
I have some plastic painter tarp if you want to give it a shot. It might be something that helps until mid July when our weather improves around here. ;-)
Good luck finding a solution. - Thx
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
01-31-2011, 04:44 PM
concrete slabs with excessive moisture...
...is something I have some familiarity with.
I have used concrete sealers to reduce moisture with some success. You'll want to use a calcium chloride test to measure the amount of moisture coming through the floor; that will determine what sealer product to use. The stuff I've used before was just rolled on. Simple.
Pretty sure that's what they do to concrete at Fred Meyer's and other grocery type stores that have concrete floors.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
01-31-2011, 11:53 PM
I've been told that a plain cotton sheet will absorb moisture off the surface, and allow it to evaporate or wick away through the fabric. Get a set of double-size flat sheets, and drape one over each wing. I meant to do it myself this winter, but kept forgetting to do it. Until yesterday my larger problem was a roof that would either drip condensation down on my wings or simply leak rain onto them. Today I moved to a new hangar with no leaks. No idea what the condensation on the wings will be like though...
Rob Prior
02-01-2011, 07:07 AM
Mark, I have had a problem in my hangar with block walls and concrete floor. I can remember times when the airplane looked like it had been sitting in a rain storm. The fix I found was to put a large piece of old carpet (either out of your house or drive around find one being thrown out in the garbage from a neighbor) it has to be big enough to extend completely under the airplane (wings and tail) you can use more than one piece put together. It has worked out great for me, try it, its free ...........
Gary
02-01-2011, 07:42 AM
COLUMBIA 400 fire
A hangar neighbor was bothered by humidity so he bought a dehumidifier and put it in his porta-hangar. It caught fire and melted his plane. Totaled!
It was about the prettiest new production plane I'd ever seen.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
02-01-2011, 09:29 AM
This really makes sense, if the airplane and the humid air are the same temperature there will be no condensation, Thanks for the great idea, I'm going to try it. The only way it can work is to have it running continuously during the cold season so the airframe says the same temp as the air. Dan, is one fan enough?
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
