01-31-2011, 08:49 AM
Sealant Gun
Can someone tell me about this gun:
http://cgi.ebay.com/Semco-6-oz-Seala...item4aa7982921
Would the ProSeal cartridge fit inside this gun, or do you mix-up sealant from the can and load it into the gun by hand?
Tom
01-31-2011, 08:50 AM
you mix and place in inserts, it works wonders if you cut the tip correctly
01-31-2011, 09:03 AM
Semco Gun
Best thing to get for sealing the tanks! You mix the proseal and scoop it into the plastic tubes and then put the tubes in the gun. You can get extra plastic tubes and tips from brown tools. I found I only needed the 2 1/2 nozzle with 1/8 opening. The dried proseal peels off the plastic easily.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
01-31-2011, 10:15 AM
Does this include the tips, i.e. can you reuse them, too?
Hendrik
Club-Libelle: flying
RV-8: on hold (new job  , new home  , no workshop (yet)  )
01-31-2011, 10:32 AM
Yes. You should disassemble the 3 parts (tube, tip and plunger) and let them dry overnight. The proseal easily peels off all of them but if you leave the plunger in the tube, it's difficult to get it out without damaging it (guess how I know). The proseal in the tip also pulls out easily. I've left proseal on the tube for weeks and it still peels off. I just unscrew the tip and then push the plunger out with a rod or dowel.
Larry New
01-31-2011, 10:58 AM
Hmpf. Reading VAF is way too expensive. Not sure I can resist this one.
Hendrik
01-31-2011, 03:45 PM
The regular proseal cartridge will fit in a regular caulk gun.
Mike
01-31-2011, 06:05 PM
Make sure you get a mixer if you use the Semco sealant tubes. MUCH easier and a better mix than by hand!
http://www.browntool.com/Default.asp...ProductID=1620
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
01-31-2011, 08:03 PM
This.
I've taken a cheap $3 mechanical caulk gun from Lowes, and removed the plunger disk, chucked it up in a cordless drill with a #10 screw and spun it against a belt sander to get the disk diameter down to fit better inside a proseal cartridge, and it works quite well with the $18 proseal cartridges from Spruce. The cartridges come with a nozzle too. If the cartridge tries to pop out of the caulk gun, just wrap a little bit of "Red Green" treatment (duct tape) around it to hold it in place
Neal Howard
Airplaneless once again...
