Old 01-30-2011, 06:18 PM
jjconstant's Avatar
jjconstant jjconstant is offline
Default removing the accessory case
I have to remove the accessory case on my engine and remove the mag gears and anything else that needs to be inspected/magnafluxed after a mag shaft failure. Is it preferable to do this with the engine still on the airframe or do I need to remove the engine for better access to the back? I'm not at the hangar looking at it...
Jeremy Constant
Old 01-30-2011, 07:05 PM
Radomir's Avatar
Radomir Radomir is offline
you do not need to remove the engine.. it'll be a PITA but it can be done w/ the engine installed.... Of course, sump has to go off first.. after you wiggle the exhaust out of the way.. Fun job
Radomir
RV-7A sold
Old 01-30-2011, 07:25 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default I'll Second...
It WILL be a PITA, I've done it this way and will never do it again!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
