Yet another Infinity grip question...
Hi,
I've been poking around the archives and I see a few threads where some folks have stripped off the blue covering from the Infinity wire, ganged all the ground wires together in the grip, then run the remaining wires out the bottom of the stick tube (this is on a -7) for a thinner bundle that won't interfere with the rod-end bearings.
I'm looking for the best way to combine the ground wires. How did you wind up doing that?
My current thought is to solder all the wires to the ring of a single terminal, then crimp that terminal down on the final ground wire exiting the stick. Would this be advisable?
RV-7 N313TD
SOLD 7/2/2020
