Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-30-2011, 06:17 AM
airbal airbal is offline
Default Garmin 420 settings
I have a Garmin GNC 420, trutrak digiflite II vs and AFS 4500 in my rv-10.
When flying GPS approach, the auto pilot flys the plane 75-100 yds to one side of rwy. Also, the EFis is showing the rwy off to one side. Any suggestions.
warren
Old 01-30-2011, 06:41 AM
mburch's Avatar
mburch mburch is offline
This can happen if the airport wasn't originally surveyed very well... for instance, there's an RNAV approach to an airport near me where the missed approach waypoint is somewhat off to the side of the runway, and I've flown into small country airports whose surveyed runway position is enough in error that the runway is noticeably displayed on a synthetic vision display. Unfortunately there's not much you can do about it.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-30-2011, 08:46 AM
Dan B Dan B is offline
I suspect you mean the autopilot is not tracking centerline. FAA flight inspection does not commission (approve for publication) RNAV procedures with such a survey data error.
Is the airplane in coordinated (ball centered, wings level) flight?
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 01-30-2011, 09:28 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default compass rose calibration...
after a compass rose calibration for my skyview system the synthetic vision displayed runways aligned spot on...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
