Old 01-28-2011, 11:17 AM
iain donnelly iain donnelly is offline
Default RV-12 gps
hi all , has anybody out there fitted a avmap EKPIV in place of the garmin, any info on wiring change avmap to dynon would be appreciated I like the avmap wich came from my last ac
Old 01-28-2011, 12:47 PM
SteinAir SteinAir is offline
We have done one EKP retrofit for an RV-12 customer. The most difficult thing you'll run into is the physical placement of it. The wiring is pretty easy (send us the harness for the AvMap and we'll just build you a new GPS harness that'll plug into your current switch panel/board like your other GPS), so no hard changes there. We've had a number of -12 builders putting in other GPSes and radios, etc... and we're more than happy to help you to the extent we can.
Stein
PS - Mod's...feel free to move this to the RV-12 forum.
Old 01-29-2011, 04:44 AM
Default rv 12 av map
Hi Stein, thanks for your prompt reply, I never had an NMEA output cable with my avmap as I only used it for nav, but now I need it for the dynon can you supply me with one and what is the rough cost including post to Scotland UK.
thanks again
Iain Donnelly
