Just sharing my recent experience with the snorkel and left baffle arrangement. I was happy to see that my snorkel actually was a good fit with it sitting pretty close to dead center of the left inlet ramp. This is on an RV7A with IO375 and Superior cold forward facing intake setup.
For anyone getting close to this stage I recommend studying the baffle instructions and the snorkel/air filter instructions till you really know them well and can easily pick out the contradictions and left out information.
The instructions are particularly deceiving in these parts as they get very specific with some hand holding involved, like reminding you to deburr the parts etc. but they are seriously lacking in the important details. The drawings for the air filter arrangement are not good.
I agree that the best approach is to use the directions as a general guide for what the end product should look like but to generally put them aside and do your own thing, very carefully.
I approached this with my motto being do not rivet anything until you really have to. This has saved me from making some mistakes. SAme thing with drilling
I have gone back a forth a few times between installing the air filter and then reverting back to finishing off the rest of the baffles in order to make sure the final placement of the cowling is not going to move and spoil my fitting of the air ramps up front. I had to cut the bafffle height down in order to put the top cowl on to double check this.
One particular area that had me confused is the baffle instructions have you making the conical gusset for both the right and left sides. The air filter retainer seems to take the place of the conical gusset on the left side when installing the filter. I am considering combining a conical gusset and air filter retainer into one part. Curious if others have done this... Perhaps after cutting so much of the inlet opening away to make room for the filter, a conical gusset is not needed like it is on the right side?
Randall in Sedona
New firewall forward install.
