Damaging fuselage while crawling around inside...
I flipped the fuselage a couple of weeks ago and am now starting to work on things inside the fuselage. I find that I need to climb in and kneel in different areas to reach things.
I'm worried whether different areas of the fuselage will support my weight. For example, could I put a board across the baggage ribs and kneel in the baggage area to reach into the tail cone? How about across the seat ribs? I guess I obviously have to at least lay across the baggage area to buck the top skin rivets.
What about the forward fuselage, can I kneel in there to buck rivets and work? Should I put a board across the angle stiffeners?
I'm sure this question has been asked before, but I couldn't find the answer even after searching around for awhile.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
