Old 01-25-2011, 05:09 PM
Av8torTom's Avatar
Default Wing Jig Question
I want to start putting my wing jig together. What is the distance between the front and rear wing spar?
Tom
N677AT reserved
Superior XP O-320, 160HP
Old 01-25-2011, 05:38 PM
bruceh's Avatar
bruceh bruceh is offline
You don't need to worry about it until you have the spars/ribs all framed together and hanging on the stand. Then you can attach the bottom support bracket for the rear spar at the right height, clamp them down and get the twist out for match drilling/riveting.
Bruce Hill
2020 VAF donator
Old 01-25-2011, 06:38 PM
Av8torTom's Avatar
Default But....
I'd like to fashion the forward spar support brackets while I'm waiting for the wing kit to arrive, and I want to be sure it's high enough off the ground - and of course, not too high either.
N677AT reserved
Old 01-25-2011, 06:43 PM
hendrik hendrik is offline
The W-711 ribs are about 26.5" long. Of course this is for an -8, i.e. a different wing.
Hendrik
Club-Libelle: flying
RV-8: on hold (new job , new home , no workshop (yet) )
Old 01-25-2011, 06:49 PM
Av8torTom's Avatar
Default OK...
Anyone have a dimension for the W-912 rib?
N677AT reserved
Old 01-25-2011, 07:42 PM
Sully Sully is offline
I don't have the dimension but I put the front spar at shoulder height for a RV-7 and that worked great. I also did both wings at once which made it go quicker
Sully
RV7 N627RS
Moving into Phase 1
Old 01-25-2011, 08:44 PM
bruceh's Avatar
Distance is approximately 26" between front and rear spars.
Chest to shoulder high on the jig height for the front spar.
Bruce Hill
2020 VAF donator
Old 01-25-2011, 09:18 PM
Av8torTom's Avatar
Default Thanks
Thanks everyone - that should get me started...
N677AT reserved
Old 01-26-2011, 10:02 AM
longranger's Avatar
I just clamped the rear spar where it fell.
http://www.cessna170.org/forums/down...1875&mode=view
RV-7 TU 904KM (reserved)
Construction Log
