01-26-2011, 07:26 AM
Would you like some beachfront property....
....in Kansas?
This house of cards will more likely than not come tumbling down.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
01-26-2011, 08:00 AM
There's a DAR in central Fl that has built two 9s for the purpose of flying as LSA. Basically he builds as normal amateur built and keeps the parameters within LSA reg. He had one at Sebring, O-235 and 2 blade wood prop with a very sparse panel--I think it was 930 empty.( I know--it's marginal useful load) He says he even had a letter from Vans himself stating that the aircraft met the lsa parameters. Just to be clear--these are NOT LSA aircraft but they fall within the metrics to fly with a light sport license.
01-26-2011, 10:31 AM
I too was left wondering what happened to the original thread...
I'm not sure if this is the same 'guy' that flybuddy is referring to...but the RV-9 and RV-9A "LSA's" being exhibited at Sebring this year were built by 4 retired firemen. They've been building 1 plane per year (sez the guy...), they moved the redline on the tach (to meet the speed requirement), they added vortex generators on the wing to beat the stall speed, and they are known real well by the FSDO guys' (sez the guy...), the implication being that this is an entirely legal arrangement.
FWIW I thought the build quality was a bit weak (even to my untrained eye...), the planes were being hawked like it was a carnival of sorts, and there were many 'winks' and unfinished sentences when I asked Q's like 'What's the endurance of the a/c as an LSA?' ('Well...you know, it kinda depends on how much gas you put in the tanks (wink, wink...) and, you know, what you do is what you do...')
The whole affair left the two of us feeling like we'd picked up some scum on our clothes from the encounter. If the way in which Mitch Lock presents the RV-12 and represents Vans is at one end of the 'This is how it should be done in the LSA World' continuum - and he is - then this was W-A-Y at the opposite end of what I think flying should be about.
Jack
01-26-2011, 11:22 AM
Are they building these airplanes for "sale"? What category are the aircraft certificated in? SLSA? ELSA? EAB?
SLSA would be the only "available" route for this type of operation, and that takes a pretty large investment the show ASTM compliance for aircraft, engine, and operation.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-26-2011, 06:42 PM
I thought they were licensing the airplanes as EAB, but were building them to comply with all of the LSA limitations by limiting the redline, limiting the gross weight, adding vortex generators, etc. Then, they can be flown by sport pilots, just like a Cub, or an early model Ercoupe can be flown by sport pilots. Is this correct?
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
01-26-2011, 07:27 PM
My point was...
1/ They are claiming to have built 4 airplanes in 4 years. That sounds like they are building them for sale. You can't do that under EAB.
2/ If you buy one of these airplanes, and operate it as a sport pilot, it will be YOUR responsibility to show that it is LSA compliant.
Operation is at your own risk!
3/ I have quite a bit of experience with Light-Sport Category and Experimental Light-Sport aircraft and I don't believe that there's any practical way to bring the RV-9 design into LSA compliance.
And the designer agrees!
01-27-2011, 07:35 AM
I agree 100% with all of your points Mel. (and the designers too!) I was just asking because some folks have been suggesting the airplanes were licensed as LSA. I can't see how that would be possible, so was trying to confirm if they are licensed EAB.
But, if a legitimate builder wanted to build an RV-9, and limit the GW to 1320, and comply with the other LSA requirements, would there be any reason not to issue the EAB airworthiness certificate?
David Maib
RV-10 N380DM
VAF Paid 1/21/2020
Jackson Browne
01-27-2011, 12:40 PM
Mel, I'm just speculating based on the discussion at the booth...but with 4 ex-firemen builders involved and building 1 a/c per year, I can imagine they rotate the official registration ownership and take the position 'Hey, built one 4 years ago, sold it and decided to build another one.' They were being pitched as E-AB completed but available to be flown under the LSA rules given the mods made to them (sez the guy).
Oily, distasteful experience.
Jack
03-20-2011, 12:24 PM
RV-9A LSA
I understand that the RV9A can be qualified as LSA. Interested in feedback from those that have gone down this path.
Pat
03-20-2011, 01:01 PM
Senior Curmudgeon
There should be a lot of info already here------try using the search, and dont forget to set it to any date, not the default of one year.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
