Old 01-25-2011, 07:42 AM
caryr's Avatar
caryr caryr is offline
Default Odyssey Battery charger
I am sure we have hashed this before.
What are the recommended chargers for a Odyssey battery??
The link at their website is broken.
I haven't gotten but 2 years from the last 2 Odyssey batteries. I am going to change floating chargers and see if that helps.
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
Old 01-25-2011, 07:50 AM
bhester's Avatar
bhester bhester is offline
Lightbulb Floating charger?
2 yr only from 2 different batteriers?
I have the PC680 battery, the same one from day one!
It and the plane are 4 yrs. old. I have only used a charger on it maybe 4 times when I was doing some panel stuff. It sounds like your using your most of the time, not sure but, maybe that is why yours are only lasting 2 yrs.
I've got about 400 hrs on my plane and my battery
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-25-2011, 08:23 AM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
The "Odyssey Optimizer" is the one I have. Works great.
http://www.batteryplex.com/odyssey-optimizer.cfm
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
Old 01-25-2011, 09:58 AM
Jeff A's Avatar
Jeff A Jeff A is offline
I use the Odyssey Ultimizer OMAX-6A-1B for the PC680.
http://www.odysseyfactory.com/chargers.html
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 01-25-2011, 10:23 AM
mike newall's Avatar
mike newall mike newall is offline
Check the motorcycle and automobile catalogues - they list several good chargers dedicated to this type of battery.
I use an Optimate, though it may not be available Stateside.
Old 01-26-2011, 09:30 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Cary, your battery life sounds way too short. I can go a month or more without flying and have no issues starting my engine. I rarely use a charger. I may have once when I was down for three months or so but that is about it.
I would look at your situation to see if you are doing something to shorten the battery life.
Old 01-26-2011, 11:52 AM
turbo's Avatar
turbo turbo is offline
Talking i would check........
on a warranty if you got one year out of it. also check if there is any drain on it when not in use. something aint right!!!!! i hate electrical stuff.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 01-26-2011, 12:17 PM
Mel's Avatar
Mel Mel is offline
I used to get 5-7 years out of my batteries. I started using a "maintainer". My last battery lasted just over 2 years.
The battery manufacturer suggested that I only use the maintainer if the airplane would sit for a month or more between flights.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-26-2011, 01:46 PM
caryr's Avatar
mel
that's about my experience also
I use a "Battery Tender Jr" brand floating charger on it all the time. I am about to believe it shortens the life of the battery.
cary
Cary Rhodes
N203CR
Van's RV-7
Old 01-26-2011, 02:01 PM
Brantel's Avatar
Brantel Brantel is offline
One thing to keep in mind with the Odyssee batteries is that you need a charger that can pump up the volts high enough....check the specs on the charger to ensure it can fully charge the Odyssee.
An Odyssee is ~ 35% charged at 12v and 100% at 12.84v
They recommend that you use a charger that can produce at least 14.7v during the charge.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
