01-24-2011, 06:43 PM
Super Moderator
Garmin 430 Card Problem
Yesterday, I fired up to come home from Tucson and my 430 would not recognize the cards. Both the Nav and Obst data was not recognizable. Just two days before I flew down with no problem and have not updated the cards for over a month. I have never had this happen before. I tried removing the cards and re-booting with no luck. Mine is a non-WAAS 430.
Any ideas out there or people have this problem?
I am going to re-flash the cards and see if that fixes it.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1280 Hours)
RV-12 N321UT (Sold)
01-24-2011, 07:01 PM
I have never had that problem.
01-24-2011, 09:48 PM
VAF Moderator / Line Boy
Sorry Scott - haven't seen it either - over five years on the 430 (non-W), and no issues with cards. Since the problem is with BOTH cards on yours, and it happened simultaneously, either you flew through one heck of a particle storm, or the problem is deeper in the unit (I suspect).
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-24-2011, 10:01 PM
Super Moderator
Well, I will let you know what I find. The conspiracy theorist in me thinks the only thing that could have happened is that someone swapped my cards out on the ramp. It was the first time I have tied down without my cover.
Very strange.
Scott Schmidt
Salt Lake City, UT
RV-12 N321UT (Sold)
01-24-2011, 10:39 PM
I did a quick google check and could not find anything. Maybe a master reset if that is an approved option.
01-25-2011, 12:37 AM
Happened to me
Scott, in early Dec I had the nav data card in my 530w fail on the return flight from a lunch run. It worked on the way out, and worked until last 5 min of flight. When I called Jepp to get another copy of current database, I ask the tech support guy how often get calls like this, he replied 2 or 3 a day. When I tried to reprogram the database, the usb programmer did not find the card. I had to buy a new card. $195 for the waas card!!
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
01-25-2011, 07:07 AM
yea,
these cards do go bad. i keep a spare for easy updating and a backup when traveling. what will a non wass card cost? i dont think a thief would replace yours with a bad one, he would just take yours. the cost of flying. how old were they?
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
01-25-2011, 09:18 PM
Super Moderator
Cards
I was able to reprogram the NAV card today with no problem, the Jepp reader worked fine. Their tech group had gone home by the time I called today but he thought it would be a hardware or software issue since both the Nav and Terrain/Obst data did not work either.
I will try and run to the hanger in the next couple of days to see if that did anything. I really don't want to reprogram the Terrain/Obst data since I have it all on the Chelton already. I can't believe Garmin charges $200 for a one time program or $280 for a new card with the new data. Plus I would need to buy the Garmin card reader that is another $200. I'm sure someone has one locally that I could borrow.
I'll see if the tech group has any thoughts. I want to find out if one card goes bad does it affect the other or the complete system.
Thanks for the replies. It all helps.
Scott Schmidt
Salt Lake City, UT
RV-12 N321UT (Sold)
01-26-2011, 06:55 AM
I have a 430 waas unit, upgraded about 4 years ago. The unit is 10 years old now. I have perhaps 3 times in the last 4 years had a "Terrain Failure" message show on startup. It has never persisted, and a power cycle has cleared the problem each time. Given that the memory cards are priced as though it is 1995, I will not simply replace the card until it flat out dies.
Has anyone ever carved open a dead memory card, to see what guts are actually in it? Since the actual chip needed costs about a dollar or two, seems a worthy project for a hacker.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
01-26-2011, 07:17 AM
There's a gent on here...
...who will swap your 430W card for an updated one for $50. I've done it twice.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
