Old 01-23-2011, 04:01 PM
aturner's Avatar
aturner aturner is offline
Default Conduit and Abrasion
Well, this is one of those "making decisions when working late at night and then waking up the next morning and feeling bad about it" situations. I ran Van's 3/4" conduit under the baggage compartment of my -10, and then riveted floors into place. I fabricated aluminum supports which attach to the floor ribs as shown below. Due to the corrugations, you have to open up the hole to the point that the conduit rattles around in there. So I put some RTV on the conduit and support, and buttoned everything up. Almost immediately had visions of the support wearing a hole in the conduit and shorting out the battery main feed. On the right side I did it right, with snap bushings or grommet protecting conduit from aluminum. Question is, is the left side setup shown below a short waiting to happen? How resistant is this conduit to abrasion? The aluminum support is 0.32, well polished.
-Andy Turner
RV-10 N784JC
Old 01-23-2011, 04:06 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Just a bit of guess work here, but I think the RTV will keep things in check.
I did the same thing in a couple places where I could not get a snap bushing, but I used shoe goo-----not a lot of difference.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-23-2011, 05:09 PM
Walt's Avatar
Walt Walt is offline
Should be fine if you used plenty of RTV to prevent movement. Next time use some Grommet strip in the holes that are to large for bushings.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
