Scott,
-My Ellison TBI "carburetor" required more cable throw than my center quadrant could put out, so I drilled another hole. Works great. When you measure, better to have a little extra throw, than not enough.
-For maximum efficiency, the cable and lever arm should be 90 degrees at mid travel (quadrant and mixture arm) position. Makes sense?? Also you don't want to approach an over-center condition at cable extreme positions.
Good Luck.
