Old 01-22-2011, 01:31 AM
Camillo Camillo is offline
Default Fuel flow transducer and bypass
I am asking to italian FAA to give me a permit to fly IFR VMC.
They asked me the compliance to CS-VLA rules for elementary airplanes.
I have a red cube fuel flow transducer. Fuel hose goes from mechanical pump to the red cube and then from here to carburator.
CS-VLA 1337 states that in case of a fuel flowmeter system, "each meter must have a means to by-pass the fuel supply if malfunctioning of that component severily restricts fuel flow".
Red cube installation sheet states that "a blocked rotor does not affect pressure drop".
Could this installation be dangerous without a bypass system? Is difficult to install a bypass system?
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 01-22-2011, 04:19 AM
rleffler's Avatar
rleffler rleffler is offline
Contact Electronics International at Support@Buy-EI.Com. They've provided great support to me in the past and I'm sure that they can help you with your situation.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-22-2011, 09:01 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The data sheet specifies that it is a FAA TSO'd part.
http://www.fdatasystems.com/Manuals/FT_60_General.pdf
And that a blocked damaged rotor will still allow flow.
The TSO approval should be good enough for your authorities...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-22-2011, 10:34 AM
Yes, I thaught the same.
Thanks.
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
