Old 01-21-2011, 02:04 PM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Tire and tubes
Does anybody take along an extra tire and tube on those long X-country's?
Also what is the best way to lift the A/C and change out a tire when ''out of town''?
Old 01-21-2011, 02:15 PM
Greg Arehart's Avatar
I carry an extra tube (both sizes) but not an extra tire. If it's a nosewheel, just hold the tail down. Tailwheel, hold the tail up. If a main, not sure what one would do in the middle of nowhere without a jack.
cheers,
greg
Greg Arehart
N 7965A
Old 01-21-2011, 02:44 PM
nomocom's Avatar
nomocom nomocom is offline
Default tire and tube....
I don't. While it would be nice to have all kind of spares, the weight and expense adds up.
I do carry a few tools and a spare spark plug, some gasket material, a little bit of electrical supplys, but that's about it. Tires and tubes are low on my list of expected problems.
I can recall one situation in the last five years where an crew would have benefited from carrying a spare tire and tube. It was a backcountry strip, a Cessna trike, and as I recall two guys in the front seats. Blew the tire and the tube when landing. They had friends fly in new parts.
My vote is for prevention. Make sure the air pressure is in spec and you aren't subjecting the nose gear to much stress (if so equiped). Keeping farther to the rear of the CG envelope will help unload the weaker nosegear, probably overall a good thing, but especially so on rough strips.
Main tire in the backcountry? Find/or make a lever and fulcrum. Use the lever and some rope (clove hitch or pruisk knot on the gear leg so the rope stays down near the axle). Hope I don't have to actually figure that out. But then, I'm not carrying the tube and tire anyway, so I suppose I'd end up asking for a the appropriate tools as well.
Stan
1990 RV-3 (now apart, upgrades in the works)
1959 C172 O-360
Old 01-21-2011, 03:40 PM
Sam Buchanan's Avatar
been here awhile
No tire but most definitely a spare tube (RV-6). The odds of a tire failure are very remote, but tubes can fail. A spare tube for a RV nose wheel is in my opinion a must-have since that tube is nearly impossible to find locally and nose wheel tubes have a history of deflating with no warning. There are numerous threads in this forum dealing with those issues.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-21-2011, 03:43 PM
frankh's Avatar
frankh frankh is offline
Default Tubes
I carry tubes.
If a main blows you simply crouch down under the spar at the outboard end of the wing and lift on your back..Not heavy.
Of course you need a helper with a car jack or block of wood/stone to place under the axle as said helper removes the wheel.
Not ideal but quite doable
Frank
Old 01-21-2011, 04:59 PM
turbo's Avatar
turbo turbo is offline
Talking i have never.......
had a main go flat but more than my share of nosewheels in 3,800. both tubes are in the plane which my also help out another fellow aviator. while landing at arcadia years ago i felt a flat nose wheel, added power and headed home to deal with it. i hate it when that happens. ft landerdale incident was a costly tow. ouch.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 01-21-2011, 05:33 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
For my 6A I carry both size tires and tubes.
Of course I am an Eagle Scout.
Old 01-21-2011, 05:47 PM
Walt's Avatar
Walt Walt is offline
Tubeless nose wheel and Michelin leak stop mains = no spares
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-21-2011, 05:51 PM
SkywayCaptain's Avatar
SkywayCaptain SkywayCaptain is offline
I didn't carry a tube until I had a flat tire on landing. Of course this happened on a Sunday with no one in the MX shop. Luckily RocketBob landed behind me and had a spare tube with him. I now carry a tube and enough tools to change a tire. The whole deal weighs less than a pound (of cure).
Drew Cook - K9QV
Sheridan, IN
RV-7 N673AC
Superior IO-360 Horizontal Induction
Hartzell C/S Blended Airfoil
IFR Steam gauges
TruTrak Digiflight IIVS
500 Hours on airframe
Old 01-21-2011, 05:52 PM
cbo111's Avatar
cbo111 cbo111 is offline
Default overkill
May be overkill and I have never had a nosewheel flat, but I carry a complete nosewheel just in case on long CC or when my destination doesn't have a suitable maintenance facility. After replacing my nosewheel tire after 460 hours of flawless performance, I realized what a pain in the butt it is to get the tube inside the rim without pinching. The weight tradeoff is worth it to me.
cbo
Chuck O
TSP
RV-7A (sold)
