Old 01-18-2011, 08:53 PM
bret's Avatar
bret bret is offline
Default Wing Dent
Ok, so a friend of mine was solo bottom skin riveting the wing and during the act of bucking and reaching one of the back rivets the bucking bar slipped out of his finger tips, fell and dented the top skin out. He was wonder if there was a good way to repair this dent?............Ok ok it was me.
Old 01-18-2011, 09:50 PM
aerhed aerhed is offline
That's why I do them upright in the wing cradle. But seriously, can you post a picture? It probably needs to be bumped inward & filled.
Actual repeat offender.
Old 01-19-2011, 06:54 AM
bret's Avatar
Taking a pic was totally deceiving and depressing. It looked like it was protruding 1/4" so I got a straight edge and measured it. Interestingly I could only get a .010 feeler gage under one side...protruding .005 thousands?, how thick is filler primer? I think the reflectivity of the skin makes it look much worse. So do I risk making it worse or leave it?
Old 01-19-2011, 07:16 AM
pierre smith's Avatar
Default You did say "bottom skin", didn't you?
So, who's gonna crawl under the airplane anyway? Put a bucking bar on the inside, lightly tap what you can and then forget about it
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-19-2011, 07:33 AM
Jamie's Avatar
Jamie Jamie is offline
Bret:
Are you going to paint your airplane or have it painted? If you can deal with it being there, just leave it. Your painter will turn the "outtie" into an "innie" and fill it. Once the metal is stretched there's no undoing it. Ask me how I know.
Old 01-19-2011, 08:13 AM
douglassmt douglassmt is offline
Default Car dent repair guy
I recently had a friend over to my shop who makes his living fixing dents on cars - say, after hail storms. Says they typically can fix 1000 dents in a day. Anyway, I had a few dents here and there and wanted to see if he could fix them before I pushed them in and filled them. Interestingly, most dents on cars are "innies" while most dents (but not all) on my plane were "outies". Outies are easier. Nothing serious, but they would need to be dressed up one way or another before paint. Bottom line, unless the metal was creased, he worked out all the dents until you couldn't see them if you didn't know they were there. It's very impressive to watch him work, very light, gentle taps and pushes. You might look into a local dent fixer, they are every where and can usually tell you by looking at it whether they can do anything with it.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 01-19-2011, 09:33 AM
akschu's Avatar
akschu akschu is offline
That is absolutely not true. You can shrink aluminum back up, that's how you build complex 3d shapes with aluminum. You can't always stretch, sometimes you need to shrink.
Anyway, for more information go checkout the master of sheet metal:
http://tinmantech.com/
schu
Old 01-19-2011, 10:29 AM
bret's Avatar
I wonder if this would work.
http://tinmantech.com/html/hail_dent_repair_kit.php
Old 01-20-2011, 12:12 AM
Flying Scotsman Flying Scotsman is offline
I want this:
http://www.boeing.com/commercial/mai...t_removal.html
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 01-20-2011, 03:53 PM
hendrik hendrik is offline
Also have a look at this post: http://www.vansairforce.com/communit...922#post471922
Hendrik
Club-Libelle: flying
RV-8: on hold (new job , new home , no workshop (yet) )
