I have a sump heater on a Superior cold air sump. I don't have a pic, but it has 2 pads that around about 2 x 4 inches or so. I mounted one on the bottom and one on the side as low as possible. There is also a thermostat. I am not sure of the brand of heater, but I believe it came from Van's. As I recall, it was a tight fit. You may want to use a different style heater. Good luck
