Old 01-17-2011, 08:37 PM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Default Items to pick up while at the Factory
I am heading down to Aurora to pick up my fuselage kit and am wondering if there is anything else I should Pick up while im there. I dont necessarily want to get anything that will come with the Finishing Kit just yet.
Any Ideas??
-david
RV-7 N87DX Built, Flown, and Sold!
Old 01-17-2011, 10:01 PM
SeanB's Avatar
SeanB SeanB is offline
Default Stuff
David,
Congrats on the fuse!
Things to consider:
Extra pedal/brake kit
Aileron Trim Kit (if you didn't get it with the wings)
Deletion of certain tailwheel components if you go aftermarket
I always like to get extra rivets and AN hardware that I commonly use
Firewall sealant (consider the expiration date)
Firewall pass through fittings
Maybe the Van's wiring harness
Good luck.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 01-17-2011, 10:23 PM
BSwayze's Avatar
BSwayze BSwayze is offline
David,
I sent you a PM. I live not too far from Vans and would be very happy to have you stop by on your way to or from Vans.
While you're at Vans, be sure to step into the little "store" in the small room next to the lobby and see what's on the shelf. You never know what you'll find there. I've picked up a few goodies now and then.
Thank you for your service to our country!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 01-18-2011, 07:01 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
OK SeanB, I am trying to make out your avatar, is that a common housefly powered with a radial engine? Definitely falls in the Experimental category.
Originally Posted by SeanB View Post
David,
Good luck.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 01-18-2011, 07:52 AM
bkthomps bkthomps is offline
what does the vans wiring harness address?
Old 01-18-2011, 11:51 AM
Hwood Hwood is offline
Get a hat......gotta have one when flying!
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
Old 01-18-2011, 02:49 PM
Flyguytki's Avatar
Should have added that, a hat and t-shirt are of course on the list
-david
Old 01-18-2011, 03:14 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
...Firewall sealant (consider the expiration date)...
Good thinking. As I understand it, that stuff is hazmat, and it's either very expensive to ship or they can't ship it at all (I can't remember which). Best to just pick it up while you're there, and save some money and trouble.
Bob Kuykendall
HP-24 kit sailplane
Old 01-18-2011, 03:22 PM
Squeak Squeak is offline
Default Manual aileron trim
Manual aileron trim for RV-7/7A,9/9A
Part Number = AIL-T79
Install when you build you will want it after flying.
Old 01-18-2011, 04:48 PM
SeanB's Avatar
Default Fly Avatar
Don,
Yep...you're correct. The radial engine is turning a very small MT Prop, too. Very complex landing gear....tough to get insurance for this model.
SEAN BLAIR V7
2020 VAF SUPPORTER
