Originally Posted by Ifly1,2
Cadstat,
Lycoming o-320-e2a Champion filter ch 48110-1. Put a little fresh oil on gasket with your finger. Hand tight plus 3/4 turn.
Regards,
John
Do this and you will over torque the filter. As I said above, I checked the torque and it is 3/4 turn from
gasket contact. This is the same filter as I tested.
As far as an oil filter sticking on the contact surface, I have never had a filter stick on any aircraft or auto that I have ever owned. Maybe it only happens if they are installed too tight and left on for years.
A standard band wrench of the proper size for the filter (same as most V8 Ford filters) will work just fine..............
