Old 01-14-2011, 07:26 AM
BGordon's Avatar
BGordon BGordon is offline
Default ugh, forgot my shoppin list
Good morning everyone,
In my haste to leave this moring, I forgot my shopping list for my trip to Avery this afternoon. Does anyone have a set of plans in front of them and can tell me the size bolts for the aileron bellcrank and tie down assemblies to the main wing spar (for my 7)?
Brandon
Brandon Gordon
KFWS, Burleson, TX
Old 01-14-2011, 08:08 AM
leaker311 leaker311 is offline
Default no prob...
the four bolts that hold the tie-down bar to the main spar:
AN3-7A with AN960-10 & -10L washers
The four bolts that go thru the bellcrank bracket, main spar, tie down spacer, and tie down bar to hold it all together:
AN3-6A with 10L washer and of course the K1000-3 platenut that gets riveted to the tie down bar.
hope I am not too late to be usefull...
Marco
Old 01-14-2011, 08:14 AM
larrynew's Avatar
larrynew larrynew is offline
I see 3 on each bellcrank:
1-AN4-32A
1-AN3-7A
1-AN3-21A
8 each on the tiedown assy:
4-AN3-7A
4-AN3-6A
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 01-14-2011, 08:37 AM
bkthomps bkthomps is offline
if you use adel clamps for pitot lines on the bolt heads, you'll want to go a size up anyway on the bellcrank angles
just a heads up
