Old 01-12-2011, 02:37 PM
JDanno JDanno is offline
Default wiring question
I'm hooking up two computer cooling fans to provide defrost air for the windscreen. It has three wires. Two are obvious but what is the third wire (yellow I think) for?? Thanks, Dan
Old 01-12-2011, 02:43 PM
roee roee is offline
The third wire is used for sensing fan speed. You can leave it unconnected.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Kahuna's Avatar
Kahuna Kahuna is offline
Yellow is speed sensor that goes to the motherboard if memory serves me. You can disregard it.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 01-12-2011, 03:23 PM
Thanks!!!!
Old 01-12-2011, 03:27 PM
noelf noelf is offline
Default On a DC powered fan...
...the third wire is used as a tach feed back to the fan controller to validate fan rotation.
On a PWM fan, you get fan power, fan gnd, and the third is pulse width modulation that defines the fan speed and also the feedback signal. This type of fan requires a dedicated fan controller chip or logic.
Old 01-12-2011, 04:41 PM
9GT's Avatar
9GT 9GT is offline
A timely post,,,,,,I just spent today installing my defroster fans in my -10. I am using one for each vent and also one for cooling the radio stack. These are light and the price is great: http://www.surpluscenter.com/item.as...tname=electric
David C.
Howell, MI
Old 01-12-2011, 05:51 PM
SteinAir SteinAir is offline
Snip it off and don't look back!
