Old 01-11-2011, 09:51 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default I have a brain cloud...
...and I can't seem to remember what the clamps used to separate the spark plug wires are called. Wire separators? Wire keepers? Turbo Encabulators?
I'd like to use something similar to keep the pitot and AOA lines tidy but haven't been able to find them and not knowing what they are called isn't helping...
Thanks!
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-11-2011, 10:01 PM
Double-Line Snap-In Plastic Clamps may be?
Old 01-11-2011, 10:04 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Hi Brad,
I seem to recall that McMaster had them but darned if I can find them or the thread that talked about them. Failing that, how about these under the "High Tension Leads Components" section.
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 01-11-2011, 10:14 PM
vlittle's Avatar
vlittle vlittle is offline
Thanks!
Is this it?
From Spruce.
Or maybe this?
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 01-11-2011, 10:17 PM
ChiefPilot's Avatar
Thanks all - Vlad got it! Those will be very helpful!
