01-11-2011, 03:00 PM
Socket for a bucking bar??
Has anyone ever shaved the thicker end of a socket flat and used it as a bucking bar? I am riveting my rudder horn brace to the rudder horn and I don't have anything laying around that can get in there. My squeezer doesn't fit and my bucking bars are to big. I have a bunch of old sockets laying around. I thought I would take one of them to the grinder and flatten the thick end of it and stick it over my finger and onto the rivet and hammer away. Thoughts...ideas?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
01-11-2011, 03:09 PM
Its worth a shot to try, but practice on a scrap piece first. Post pictures if successful or not, we can all learn what to or what not to do.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
01-11-2011, 04:18 PM
I did something similar with a the polished side of a crescent wrench in a few places. It worked ok for AD3 rivets but I wouldn't try it with anything bigger.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
01-11-2011, 04:20 PM
You need mass. If you can add weight it would help.
01-11-2011, 05:28 PM
According to legend, every A&P has bucked a rivet with a dime. Also, every texan has drunk water from a hoofprint (True Grit).
Actual repeat offender.
01-11-2011, 06:40 PM
Ouch
I don't think I'd like to stick my finger in there...
If it's a deep enough socket, fill it half with molten lead to give it added mass, then fit in a wooden dowel to hold on to.
I used my squeezer yoke to buck the rivets on the horizontal stabilizer nose ribs.
01-11-2011, 08:46 PM
OUCH!!! *%$)!# $%%! $#%^$!!!!
Man that's going to hurt. Try it and let us know!
I actually back riveted mine...
- Put the rivet in the hole.
- Put the rudder/rivet/hole on a back riveting plate.
- Grabbed a really big crow bar.
- Laid the crow bar on the backside of the rivet.
- Cranked the gun up to ~90 lbs.
- Shot the back side of the crowbar in bursts.
It's not the prettiest rivet in the airplane, but it isn't bad.
01-11-2011, 09:54 PM
VAF Moderator / Line Boy
Two Words...."Cherry Max"
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-12-2011, 10:01 AM
It's been a while, and it was an RV-4, not a -9 but I remember being able to reach through the lightening hole with an Avery longeron yoke to squeeze all of those rivets.
RV-7 TU 904KM (reserved)
Construction Log
01-12-2011, 01:08 PM
You're talking about this piece, correct? I used a tungsten bucking bar, no problem. If you don't have one yet, this is a good reason to get one.
