Old 01-11-2011, 10:24 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default Gas Tank Drain valve Replacement
I have an almost totally stuck gas tank drain valve on the RV I bought that also has a slight drip. I bought replacement valves from Van's. Do I need to use pro seal on the threads when I replace it or is there something better?
Old 01-11-2011, 10:30 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
No proseal.
Use fuel lube.
http://www.vansairforce.com/communit...ead.php?t=8791
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-11-2011, 11:40 AM
AltonD's Avatar
AltonD AltonD is offline
now known as EZ Turn fuel lubricant.
http://www.aircraftspruce.com/catalo...ezturnlube.php
The 5 oz tube should last the life of your airframe.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 01-11-2011, 12:05 PM
frankh's Avatar
frankh frankh is offline
Default Or
teflon paste from the hardware store.
if you intend to have any ethanol in your gas you'll need to replace the Orings with flourosilicone ones from McMaster Carr..Easy mod for a few cents.
Frank
Old 01-11-2011, 12:27 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Aircraft Spruce
Aircraft Spruce has them also. They also have just the seal so you repair the old one to keep as a spare in your tool bag.
http://www.aircraftspruce.com/catalo...ges/safair.php
These are easy to swap out even with fuel in the tank. Put the fuel lube on the threads of the new and put a bucket under the drain take the old one out and put the new one in. You won't get much fuel in the bucket.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-11-2011, 12:29 PM
Mike S's Avatar
Senior Curmudgeon
Leave the fuel cap on, and plug the vent line first, and you will slow down the leak quite a bit.
BE SURE to remove the vent plug before flying
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 01-11-2011, 01:19 PM
Cadstat's Avatar
Default Thanks to All
THANKS TO ALL WHO REPLIED!! Great advice all around.
Old 01-11-2011, 01:41 PM
Capflyer's Avatar
Capflyer Capflyer is offline
I find that at least once every six months one of the drains start to drip. I now don't put anything on the threads and have had no leakage problems around the threads plus it makes it easy to remove, clean and reinstall. Most of the time I find a tiny spec of dirt around the o-ring seal which is easily cleaned. I keep a cleaned extra now so when I remove one, wearing a glove of course, plug the hole with a finger as I bring the spare into place. At most I'll loose about 4oz of fuel doing it this way...most of which ends up running down my arm (good thing I wore that glove )
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 01-11-2011, 05:10 PM
aerhed aerhed is offline
I always tie shop rags around my wrist too. Keeps the "tingle" from reaching your armpits.
Actual repeat offender.
Old 01-11-2011, 06:08 PM
Kyle Boatright Kyle Boatright is online now
I put my thumb over the hole when I remove the leaky one, have the new one handy, and insert it right after removing my thumb. I spill less fuel than I waste checking a sump.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
