Old 01-10-2011, 09:42 PM
RLrothJr RLrothJr is offline
Default 0-320 C/S prop
Hey Folks,
I am new to the RV world. As a matter of fact I just purchased an RV-6. It is equipped with an o-320 and a c/s Hartzell prop. Any ideas on where I can find some info on how best to operate this engine and prop combination.
Rick
Old 01-10-2011, 10:10 PM
SMO's Avatar
SMO SMO is offline
This is from my notes during transition training with Mike Seager in the -6. I used this till I was comfortable with the c/s and then adjusted as I saw fit.
Take Off: Throttle Full, Prop Full Fine
Climb: Throttle 25” MP, Prop 2500 RPM
Pattern: Throttle 18” MP, Prop 2300 RPM
Approach : Throttle 1800 - 2000 RPM, Prop Full Fine (use like a fixed pitch through approach, landing and go around, just make sure prop is full fine)
High Cruise: Throttle 24” MP, Prop 2400 RPM
Medium Cruise: Throttle 23” MP, Prop 2300 RPM
Low Cruise: Throttle 20” MP, Prop 2300 RPM
Slowing for Pattern : Throttle 14” MP till 110/120 then 18”, Prop 2300 RPM
Reduction order: Throttle - Prop - Mixture
Increase order: Mixture - Prop - Throttle
Also note that when pulling the throttle back keep pulling until under the target MP. When you pull the prop back the MP will increase. Don't be a slave to the numbers, close is good enough, fly the airplane.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 01-13-2011, 08:36 AM
Attakpilot's Avatar
Attakpilot Attakpilot is offline
Rick,
That is a very good guide that Mark wrote. Notice there is no rpm operation between 2000 & 2300 rpm. Check the engine & prop combo you have to see if there is an area to avoid. The 0-360 and hartzell on our 8 says avoid 2050 - 2250 rpm. Other than that, operate as prescribed in Marks email and enjoy the climb performance!
RV-8
1/2 RV-4
Old 01-13-2011, 09:50 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Numbers
If you like numbers, consider that the formula for HP is Torque X RPM, so changing either side of the formula affects horsepower. Without a CS prop, the throttle controls both MP and RPM. The CS just lets one fine tune HP for every condition.
YMMV
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 01-13-2011, 11:59 AM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Check out http://www.hartzellprop.com/kitplane_details.php?id=38
If that is your prop/engine combination, then you're lucky, there aren't any RPM restrictions other than using MP/RPM/Alt combinations that are approveed by Lycoming.
Old 01-13-2011, 06:02 PM
jrs14855 jrs14855 is offline
Default prop
To use the full range of power options it would be best to get the power setting information from a certified engine/prop combination. Also don't hesitate to use full throttle/full r/m any time you need it for as long as you need it.
Old 01-13-2011, 07:31 PM
java's Avatar
java java is offline
Default Welcome
Originally Posted by RLrothJr View Post
Hey Folks,
Rick
Hey Rick. Welcome from another new RV6 owner. Good advice exists here. I took the same training with Mike Seager, so have nothing to add re: engine ops to what has been said above, but saw it was your first post and wanted to welcome you.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 01-23-2011, 08:33 PM
Default C/S Props
Thanks for all the clues! I know this is a stupid question but who is Mike Seager?
Old 01-23-2011, 08:41 PM
Thanks. Just what I needed to know. Who is Seager?
Old 01-23-2011, 08:42 PM
CPSONE's Avatar
CPSONE CPSONE is offline
Default MP
Watch manifold pressure as you descend. It will climb about 1 inch per 1000'.
The opposite happens in the climb...
Mike Seger = http://www.vansaircraft.com/public/trainfly.htm
first one in the list.
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
