Ok, hereby i have to officially admit that my knowledge about airplane engines is somewhere at the zero level. so please don't laugh.
here's my question: i bought an io-375 that hangs already at the airplane. a fuel line is running from the boost pump through the firewall to the mechanical fuel pump and from there to a thing that is at the bottom of the engine. i expect that this is the throttle body. through the same thing the air comes in.
on top of the engine sits the injection distributor. another funny device from where you can see four lines running to each cylinder.
so, do i have to run i fuel line from whereever to the injection distributor? does the engine gets it's fuel from both sources?
sorry for the dumb question... i am still in the basic learning process.
Kay
