Old 01-08-2011, 10:26 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Electric heater actuator?
In my never-ending quest to make my build last forever, I'm wondering if it makes any sense to use an electric linear actuator for the heater bypass valve. Has anyone ever done this? If so, what actuator did you use?
My motivation is that I just don't like the way the heater pull cable is routed - feels like it might get in the way of something if I do it as suggested.
Looking at something like this:
http://www.firgelli.com/products.php
Thanks!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-08-2011, 11:22 AM
dpansier's Avatar
dpansier dpansier is offline
I have my heater control setup with a Futaba model aircraft servo controlled with a Perihelion Design controller.
Links here:
http://www.servocity.com/html/s3004_...l_bearing.html
http://www.periheliondesign.com/more...Controller.pdf
I built up a simple linkage to connect the servo to the door keeping the servo out of the heated duct area, seems to work well but I'm not flying yet.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 01-08-2011, 12:53 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.nwacaptain.com/heatcool.html
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
