ELT Recommendation by NTSB
I saw it somewhere today too. However, it's a RECOMMENDATION by the NTSB to the FAA, so it may take a while for it to reach us. Seems the search for the crash that killed Sen. Ted Stevens in Alaska was hampered substantially because they didn't have an ELT signal. When they found the wreckage, the ELT had activated but it was separated from its mounting bracket and its antenna.
Say, wasn't a Senator's or Congressman's death in Alaska way back in the '70's the reason ELT's were mandated in the first place? [See "P.S." below.]
Interesting...
Alaska is a challenging place to fly, PLUS there are a LOT of airplanes flying there.
Don
P.S. Here's an excerpt from Wikipedia: "The original impetus for the program in the U.S. was the loss of Congressmen Hale Boggs (D-LA) and Nick Begich (D-AK) in the Alaskan wilderness on October 16, 1972. A massive search effort failed to locate them. The result was a U.S. law mandating that all aircraft carry an emergency locator transmitter."
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Reason: Added the P.S. and corrected the failure mode described.
