Is vans hartzell BA aerobatic?
In "prop" terms no...
F74972 / F7666A-2 refer to the blades which are not relevant to "aerobatic" or not.
Hartzell Manual
The last one you list is "aerobatic" since it is a -4 - see Manual p2-1 for index. These use counterweights such that when Oil Pressure is lost, the prop coarsens, and does not overspeed. Counterweights come at a weight, and presumably cost, implication, and need different governor type/setup.
To put a -4 in an RV is rare, but not unknown. There is one horror story of someone doing a detailed test profile who did seriously overspeed his prop / engine, and unsurprisingly now has a -4
Details somewhere here on VAF.
To require the -4, you would probably want to do serious aerobatics, with extended -ve 'g', and RVs are not good in this area. I use a standard -1, tend to aerobat using ~2400RPM, and if -ve 'g' is ongoing, listen carefully - you will hear the engine beginning to increase in speed, and can throttle back. OTOH if you have 2600+ RPM set, and are distracted / unlucky, you might get well beyond 2700RPM
[NB you are allowed without inspection +10% for 3s = 2970RPM on a Lyc, 10% for nearly 30s on a Hartzell].
From your post, I would go for the F7497 -1 - whether 72" or 74" see elsewhere for the debate
HTH?
Andy
RV-8 G-HILZ
RV-8tors
