Originally Posted by AX-O
I have been trying to figure out what code to use based on my onboard equipment. I have a Garmin 396 with XM weather, Mode C and the applicable charts.
XM weather is irrelevant for equipment suffix, btw. Wouldn't matter if you had on-board RADAR or any other equipment for weather. The equipment suffix is to describe *installed* (not handheld) equipment for *air navigation*.
I presume you meant you had a Mode C transponder? (ETA: I see that now in your second line...sorry...)
Likewise, whether you have charts on-board or not doesn't matter for equipment suffix. (However, if you're using electronic charts in your on-board equipment, such as a panel-mount GPS, the database must be current).
This will probably restart some old debate about using handheld (not "installed") equipment for IFR
. Lord help us.
Steve
