Old 01-04-2011, 10:24 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Default Oops dimple
I'm sure I'm not the first to have done this, but I cant seem to find anything doing a search. I'm working on my practice project and in my haste I accidentally put a dimple the wrong direction.
I was in the process of dimpling a 'skin' and I had turned the work over to inspect something or another. and just started dimpling again without thinking. I made two very nice backwards dimples when I realized my mistake. It is just a practice project, so I just flipped the piece over again and re-dimpled it the correct way but it got me to thinking. What happens if I do this during the build? Do you just flip it over and re-dimple it the correct way?
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 01-04-2011, 10:37 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Flatten the dimple first, then dimple it the other way. No problem.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 01-04-2011, 10:38 AM
Auburntsts's Avatar
Well, I'm sure it's probably not the "right" thing to do, but I did exactly what you did--twice to be exact. On different parts I dimpled the wrong side of one hole, caught the mistake, and simply reversed it. For a one or two holes, I don't think it's an issue, just inspect the hole(s) to ensure no cracks developed in the process.
On the other hand, if I had done a whole skin (and couldn't swap turn it over and swap it top for bottom or left for right), I wouldn't try and fix it but would order a new one and start over.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
