Old 01-03-2011, 05:24 PM
Cement85 Cement85 is offline
Default Heated Pitot tube
Have any of you had problems with the pitot tube freezing up?
Friend of mine has a Cherokee and had this happen to him several times in the last week.
He is an experienced IFR pilot, IA the whole nine yards so I do not question that it is occurring.
Anyone have heated pitot tube on any of vans products?
Old 01-03-2011, 05:47 PM
SkywayCaptain's Avatar
SkywayCaptain SkywayCaptain is offline
If you fly in visible moisture and the temp. is below freezing, the pitot may (will) freeze. I have had it happen years ago in other aircraft. My RV has a heated probe, but you might ask yourself if you should be flying in icing weather without full deice
Drew Cook - K9QV
Sheridan, IN
RV-7 N673AC
Superior IO-360 Horizontal Induction
Hartzell C/S Blended Airfoil
IFR Steam gauges
TruTrak Digiflight IIVS
500 Hours on airframe
Kevin Horton's Avatar
I've got an AN5812 heated pitot tube on my RV-8. Works great. The only gotcha is that you need to turn if OFF very shortly after landing, to give it time to cool down before putting the pitot cover on.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
