Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-02-2011, 04:05 PM
jrouault's Avatar
jrouault jrouault is offline
Default GNS430W and SL-30 with single Archer Nav Antenna
I currently have a Bob Archer nav antenna in my wingtip that I have hooked up to a CI-507 Diplexer (http://www.aircraftspruce.com/catalo...coupler507.php) that then feeds VOR/ILS and Glideslope to my GNS430W. This configuration has worked very well. I would like to add an SL-30 and attempt to re-use the same nav antenna. Since the SL-30 has a built-in diplexer, it sounds like I have a couple of different options. I can add a splitter prior to the diplexer for the GSN430W, or replace the diplexer with a triplexer. I am curious what people have done with a similar setup to mine, and what kind of antenna performance (or lack of performance) they saw.
Jason
Jason Rouault
RV-7A TMX IO-360 3-Blade MT CS Prop, Flying
Fort Collins, CO
http://www.rouault.us
Old 01-02-2011, 05:23 PM
Brantel's Avatar
Brantel Brantel is offline
To use a triplexer, you need to ensure that the triplexer does not strip off the G/S signal from the second VOR port. If it does, the SL30 won't get good G/S signal. These things are not all made the same way inside.
The splitter before the diplexer is the best bet. You will lose some sensitivity no matter what you do.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-02-2011, 05:54 PM
Radomir's Avatar
Radomir Radomir is offline
I bought a Comant CI-1125 (from Cirrus on Ebay) and that seems to work very well in our setup (530W/430W).. it's the 2x VOR + 2x GS splitter.
Radomir
RV-7A sold
Old 01-02-2011, 07:21 PM
Brantel's Avatar
Not the same setup...the SL30 has a built in diplexer....
Old 01-02-2011, 07:24 PM
jay.pearlman jay.pearlman is offline
Default suggestion
Here is the way I am using one archer antenna for a 430 and an SL-30. I used the figure at the bottom with a single antenna.
Thanks to Jason of Aerotronics for the diagram.
Old 01-03-2011, 07:32 AM
jrouault's Avatar
Thanks all for the reply. Sounds like I should try a splitter/coupler prior to my existing diplexer. Comant makes the CI-502 (http://www.aircraftspruce.com/catalo...coupler502.php) that looks like it would work.
Jason
Jason Rouault
Fort Collins, CO
