Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-01-2011, 02:28 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Garmin 496 question
For those using the 396/496 I have a question.
During the building of my RV-7A and testing of the 496 at my home the display showed the standard terrain you would expect. You could zoom in and out. When I moved the airplane to the airport and the 496 displays the airport map (almost full screen-auto zoomed in to the airport). I thought this might be because the 496 knew I was at the airport and not moving so it may default to the airport map. However it appears that even when flying in the pattern it still is defaulting to airport map mode. Is there a way to shut this auto function off?
I can't find the setting in the manual.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 01-01-2011, 02:46 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Smart taxi
When I'm anywhere near an airport with the safetaxi diagram it will display the white box out to I believe the 20nm range. If you are staying in the pattern close to the airport and haven't zoomed out far enough the white bounding box of the safetaxi diagram will always be shown. Try zooming out to a long distance and you will see how the white box varies size and eventually disappears.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 01-02-2011, 12:09 AM
PCHunt PCHunt is offline
Somewhere in the setup menu system is a box to check for auto-zoom. If auto-zoom is selected, as you get closer to each checkpoint in your flight plan (including the destination), the Garmin will zoom in, showing more detail.
You can always override this by hitting the "in" or "out" button. As you pass the checkpoint, it automatically zooms out again.
You can turn this feature off and on in the menu.
Personally, I like the autozoom feature.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
