Old 12-31-2010, 08:47 PM
Phil's Avatar
Phil Phil is offline
Default Witness Holes
I have a question for those of you who are putting witness holes in the ends of your push tubes. I'm curious to know 3 things.
1) What size is the hole?
2) How do you check it? Visually or with a probe that's poked through the hole? - Is there enough light to actually see something in there?
3) What was your criteria for locating them?
I think witness holes are a great thing and I wish I had thought of putting them in earlier. Now I've got a few to pull out of the airframe if I want to check all of them.
Phil
Old 01-01-2011, 05:16 AM
pierre smith's Avatar
Default Happy New Year, Phil
On my Air Tractor and other certified airplanes, the witness holes will accomodate a piece of safety wire, making it easy to check.
An easy way to ensure that your threads are deep enough is to apply some torque seal or finger nail polish...even a Sharpie marker to the threads before you screw in the end and simply run it down to the painted area.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-01-2011, 06:17 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Hello Pierre and Phil
Interesting thread!
I would also know how much the thread engagement should be (so you can position the witness hole). I heard once 1,5x the thread diameter, but with the Vans design, the tubes are on the short side and the threads are less then 1.5x engaged. Look also here what I like to know: http://www.vansairforce.com/communit...t=aileron+tube
Hopefully someone can help.
Happy new year!
Regards, Dominik
