Old 12-31-2010, 09:14 AM
ao.frog ao.frog is offline
Default Any difference in sag beetween Vans std rubber mounts and Lord mounts?
Hi.
We're about to start trimming the cowlings and baffling. On dwg 45 it says to use 1/8" by the top of the spinner and 1/8"-3/16" by the bottom edge.
I assume this is measurements for Vans std rubber mounts.
In Vans FF-kit which I bought this fall, they sent me Lord mounts and that was fine with me ofcourse, but I'm wondering about future sag?
Is it any less (or more for that matter) sag with the Lord mounts compared to the rubber mounts Vans used to have in their FF-kit?
Schould I adjust the measurements called out for at the dwg or use the same?
Thanks!
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
