Old 12-24-2010, 08:34 AM
Louise Hose's Avatar
Question Remember those flooded RVs at LOE several years ago?
Either the last year of the Land of Enchantment RV Fly-In at Las Cruces or the first year at Santa Teresa (I forget which one), departure morning was marked by the somewhat humorous sight of folks gathering around about a half-dozen tail-draggers, lifting their tails as high in the air as possible, and draining water out of the planes' snouts. Heavy, blowing rains the night before had entered the cowling and somehow prevented injected engines from starting the next morning. I haven't flown an injected engne and, with Junior's injected engine now on-site, I'd like to better understand what happened that night/day, whether Junior's engine might be prone to a similar incident, and, if so, what we can do to prevent it happening (i.e., will cowling plugs stop it?). Look foreward to being educated!
Old 12-24-2010, 08:53 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Convert to an A model
Old 12-24-2010, 09:05 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Just a WAG here, but injected engines dont have a fuel drain (sniffle valve IIRC) in the FAB.
Thus, water can pool in the FAB if the wind drives the rain into the air intake.
Merry Christmas
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-24-2010, 09:13 AM
Martin Sutter Martin Sutter is offline
Super Moderator
Hi Louise,
Depending on the configuration of the air intake duct, a small hole drilled on the bottom of the duct just before it joins the throttle body will allow any water that enters the duct to drain out before it enters the engine. That works well with Van's "snorkel" as supplied for the RV7 and 8 with F.I. engines with the forward facing horizontal throttle body. This duct has an annular bulge just before it connects to the throttle body and provides a trough to catch the water if a hole is drilled in the bottom of it. However I doubt that Van's supplies a duct for the RV3 so you will most likely have to make your own and it would be simple to mold a small depression in it and copy Van's design.
The other option is the installation of a sniffle valve in the bottom of the air plenum. This check valve allows accumulated fuel or water to drain though a tube that exits the cowling in the exhaust pipe outlet area.
Merry Christmas to you and Paul and hopefully better weather in California,
Martin Sutter
building and flying RV's since 1988
EAA Technical Councelor
Old 12-24-2010, 09:15 AM
Walt's Avatar
Walt Walt is offline
Assuming you have vertical injection, a strategically placed hole in the bottom of the airbox will do the trick. This is also recommended to avoid pooling fuel in the bottom of the box (in case you forget you have FI and leave the mixture in with the FP running).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 12-24-2010, 09:20 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Louise,
I have the drilled hole mentioned above by Martin/Walt, but also, I have the standard cowl inlet plugs Vans sells. Our -7 has sat out in driving rain more than once in the last few years and we've never had any issues as long as the plugs were in.
RV-7 Flying since 2004
1,100 hrs+
Old 12-24-2010, 12:58 PM
AlexPeterson's Avatar
If the problems at LOE were all with injected planes, it would seem to be a coincidence. I was there that year, and had no problem. All induction systems which could potentially pool water or fuel need to have a hole drilled in the appropriate place (as do the fuselages!). I have two holes in the bottom of the FAB, one just inside the filter and one at the aft end, outside the filter. The holes need to be large enough that the surface tension of the water doesn't prevent draining, maybe something like 3/16" or so. I glued a fitting to the outside of the FAB, over the hole which is on the inside of the filter. This is where excess priming fuel goes. I attached a hose to this fitting to direct the goo out the back of the cowl. If your injection system does not have a purge valve, it will barf fuel through the injectors after you shut it down (as fuel boils and percolates). This fuel ends up pooling in the FAB if there is no drain hole inside the filter.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 12-24-2010, 01:08 PM
Default Rv-3B-A?
An "A" model RV-3B? Now wouldn't that be special!
Thanks, guys, for the information.
Old 12-24-2010, 04:19 PM
Ron Lee's Avatar
Alex makes a good point about the hole size. I tested that a year or so ago when deciding what size hole I needed in the fuselage aft of the cabin to drain water. The water accumulation happened in Florida and was unexpected. I don't recall the hole size (which is a function of the water pressure of course) but may have been in the vicinity of 3/16". If I remember, I will measure it later.
Old 12-25-2010, 04:46 AM
plehrke's Avatar
plehrke plehrke is offline
I have two holes as well. Used 1/8" holes. The diameter of the hole is also a function of the thickness of the material.
One other place nobody has a hole is in thebottom of the rudder. One year at OSH there was a lot of rain and I noticed the botom of the rudder was full of water. Since I had no drill, I went to the fly mart and bought some cheap hose to suck out the water. Drilled the hole when I got home.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
