12-23-2010, 09:28 PM
AN reducing tee?
Is there any such thing as an AN fitting reducing tee? I'd like to find one similar to an AN824, but with 6D on both ends of the run and 4D on the side.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
12-23-2010, 09:55 PM
Aeroquip catalog
This is one of the best references I've found for AN fittings:
http://hydraulics.eaton.com/products...E5_Catalog.pdf
They're a bit scattered throughout the catalog, but it's a pretty comprehensive listing.
M
12-23-2010, 10:24 PM
I couldn't find one
Chris
RV-8 Wings
12-24-2010, 10:20 AM
...for the references.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
12-24-2010, 11:19 PM
Try this.
1ea AN818-6D -6 Aluminum B-nut
1 ea NAS1564-6-4D Aluminum Reducer Nipple -6 to -4
Put the Reducer Nipple on the -6 fitting, secure with the -6 B-nut.
If you have the room this is an easy fix.
12-25-2010, 12:09 AM
Does not exist
The lack of availability of this fitting has frustrated me for years and I spent hours trying to find it.
As far as I know it does not exist and yet every airplane needs at least one or 2 of those.
Yeah, I know you can cobble 2 fittings together with a reducer to get what you need, but why is this fitting not made?
Anyone know the answer?
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
12-25-2010, 09:52 AM
Earl's has one, but the one I found has 2 #8's, and one #4. They might make one at Earl's with #6AN, I couldn't find it though. Here's the 8AN/4AN:
http://www.summitracing.com/parts/EAR-982484ERL/
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
12-26-2010, 11:43 AM
purge line check valve
Thanks all, but I've since decided to put a check valve in my purge line and since the cheap one from ACS uses -6 ports, I have to reduce it down anyway. Andair has a nicer check valve with configurable ports which could serve double duty as both check valve and reducer, but I can't see paying twice as much.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
12-26-2010, 12:10 PM
