Old 12-22-2010, 06:45 PM
Bavafa Bavafa is offline
Default Canopy warning light
My plane is down for another week while my ADI is being repaired and as in between, I am considering installing a switch that would show if my tip-up canopy is not fully closed and was wondering if any one has done this so I don't reinvent the wheel.
I was thinking of installing a couple of miniature momentary push-button switch in series that would be installed near the roll bar (on each side) that gets pushed to close when the canopy is all the way down, connected to a LED on the panel.
All thoughts are welcome?
Thanks in advance & Happy holidays
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-22-2010, 07:18 PM
frankh's Avatar
frankh frankh is offline
Default I did the same
Almost but as I know bright sunlight will wash out just about any light I decided to use a cheap buzzer from Radio Shack instead.
My limit switch is placed under the forward part of the canopy such that the arm of the canopy depresses the switch about 2" above the closed point.
It has saved me draining the battery a coupe of times..
But of course if one were to use a checklist then the need would never be there..But just in case..
Frank
Old 12-22-2010, 07:33 PM
roee roee is offline
Default My variation on the theme...
I mounted my switches (one left and one right) in such a way that they only engage if 1) the canopy is closed AND 2) the canopy latch is engaged.
Description and photos:
http://www.kalinskyconsulting.com/rv..._warning_light
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 12-22-2010, 07:34 PM
gasman gasman is offline
Yes, two switches needed....... The first one says the canopy is in the down position. The second switch, wired in series would tell you that the latch is in locked position.
EDIT...... Do what Roee did on the post above mine. I like that. And it can be done just fine with just one switch.
Old 12-22-2010, 07:41 PM
A single switch can be used to detect both that the canopy is closed AND that the latch is locked. See link in my previous post.
Two switches needed though, one for left and one for right side. In the ideal world, one side would suffice. But in reality there is enough flexibility in the canopy frame that it could potentially be down and locked on one side and not the other, in which case we'd want the canopy warning light to remain lit.
Roee Kalinsky
Old 12-23-2010, 05:40 AM
clevtool's Avatar
clevtool clevtool is offline
The RV4 was much simpler in installation, but we used a switch similar to the one in Roee's post. We used a single pole double throw (SPDT) switch and a bi-color LED so that it shows red when open and green when closed. We also put a tiny machine screw with a double nut through the actuator arm so that it has a highly sensitive adjustment.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 12-23-2010, 08:58 AM
Thanks all, I was thinking of some thing in line with what Roee has done but with a different type switch, but I like his better and found a switch at Mcmaster. It will be a STDT-NC. I do not see a simple STDT will work as it needs to be a momentary type switch.
Roee, do you remember what type of switch you used?
Thanks again and happy holidays
Mehrdad
Dues paid
Old 12-23-2010, 02:50 PM
Mehrdad, the type of switch I used is momentary SPDT, i.e. it's a 3-terminal device: one common, one normally open, and one normally closed. So you can wire it however you choose.
It's a common form factor available from many different manufacturers and many different ratings. You can spend $100+ on some high-current, environmentally sealed, aerospace temp rated part from Honeywell... or you can spend $1 on a commercial grade part from China... or anything in between. The cheap stuff is fine for this application.
Some part numbers here:
http://www.kalinskyconsulting.com/rv...70722_switches
Happy holidays,
-Roee
Roee Kalinsky
