Old 12-22-2010, 10:07 AM
ao.frog ao.frog is offline
Default A KISS engine warmer with no a/c mounted parts, and works GREAT too!
Hi all.
Here's my cheap and dirt simple engine warmer. It does a great job heating the engine, the battery AND the oil-cooler. As you can see, it heats up the entire engine compartment. :-)
It consits of a 1400 watt heater made for heating the interior of the car, a camera-stand and a homemade mounting plate.
Here's the warmer on the stand:
To mount the warmer on the camera-stand, I made a plate and matchdrilled it to both the mount on the camera-stand and the mount on the warmer:
(The stapler is there just to give you an idea of the size of the bracket)
Here's the warmer in it's place on the stand:
And here's the whole setup in place:
In the foreground, you'll see a white "thing" with an antenna sticking up. This is used to turn the heater on. I simply call it up from my homephone beetween 2 and 3 hrs before I'm going to fly, enter a code and the "thing" turns on power to the warmer.
Thus, when I get to the airport, the entire engine compartment is nice and warm.
To further speed things up, I've covered the top cowling with a blanket and installed the Vans cowl inlet plugs.
The inlet plugs are installed with a little gap so the "used" warm air can flow out of the inlets.
I guess all these articles can be found in every country having cold weather during winter, so hopefully this can be a tip to others needing to preheat the engine.
I prefer this preheating method over others because I don't have to mount anything on the engine or aircraft itself.
That's both simple and doesn't add weight to the plane.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 12-22-2010, 10:12 AM
Brantel's Avatar
Brantel Brantel is offline
Cool, (or warm) but I want to know more about the "white thing".
What is it, where did you get it, how much does it cost?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-22-2010, 10:58 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Not the exact same brand/model, but here's a couple links to a GSM cellphone-based device (can use cheap prepaid SIM cards for cell service).
http://www.gsm-auto.com/
http://wurtsboroelectric.com/preheat.html
Other pager-based device:
http://www.preferredwireless.com/hom...awk-nh100-air/
Neal Howard
Airplaneless once again...
Old 12-22-2010, 10:59 AM
Default Here...
... is more info about the "white thing", or schould I say "the remote switch":
http://www.ondico.se/files/manuals/1...5035_IB_EN.pdf
They work on the same band as your cellphone and to get it to work, you need to buy a phonecard (SIM-card) so the unit gets it's own phone-number.
The most common way of using these, are in a cabin: You connect them you the heaters in the cabin.
Then, you call it up from the housephone (or your cellphone for that matter) before leaving home and turn on the heat in the cabin.
When you arrive a few hrs later, the cabin is nice and warm.
So it's actually a thing that can turn electricity on or off.
It's practical that it also can turn OFF the power, because if you have to cancel your planned flight at some point before getting to the hangar, you can just call it up and turn off the warmer again.
I've bought it here in Norway and it costs about 1300 NOK (approx 220 USD)
A more pricey version is sold by Aerotherm Heaters in the US:
http://aerothermheaters.com/product_desc.php?id=6
Old 12-22-2010, 06:51 PM
breister breister is offline
Or, you could simply move someplace warmer...
Nice idea!
Old 12-22-2010, 07:02 PM
smokyray's Avatar
smokyray smokyray is offline
Default Full of Hot Air
Step one> Drive to Wal-Mart
Step two> Purchase cheap blow-dryer
Step Three> Pick up honey do list items while there
Step four>drive home, go to hangar (if not co-located)
Step Five> Place hair dryer up into lower cowling between exhaust (cowl plugs in) Technique: make hook from coat hanger, wrap around nozzle. Hangs from lower engine mount tube.
Step six> Turn on high, go get coffee or a spot o' tea, warm for 20 minutes or until top of cowling feels warm.
Go fly!
Step Seven, like previously mentioned, move where it's warm!
Smokey
HR2
Old 12-22-2010, 11:01 PM
Default Here's...
... the interior heater I'm using:
http://wup.defa.com/en/wup_products_...orheaters.html
I want to use a product that is made for use (that includes starting up) in low temperatures and has a ground wire.
I hope that my insurance company won't make trouble then, if something schuld happen (fire for example)
In the temps we're having in Norway in this part of the country during winter (-20*C = - 8*F) 20 minutes of warming isn't nearly enough.
Further north the temps are much lower...
But the low temps can be nice too; in high pressure situations the air is stable, still and smooth as silk so it's nice to invite the wifeys to lunch now and then.
Here, a friend of mine and I has just landed after a 2-ship mission to Notodden airport (20 minutes away from my home airport) a couple of weeks ago.
And during the 20 minute walk to the small town, we passed this tree:
Mother nature sure knows how to make nice winter-art! :-)
Regarding moving; well; on the 1st of February next year, I'm getting at early retirement at the age of 55 from my airline, so we'll see what the future holds...
Old 12-22-2010, 11:51 PM
Hwood Hwood is offline
Default early retirement
Early retirement from the airline? What's that?
Hwood
N469SH / "Crazy Woman" (sold)
Working on Another -8
Exempt but paid
Old 12-23-2010, 04:47 PM
cjensen's Avatar
cjensen cjensen is offline
That's a fantastic idea Alf! Can you post up some details on the heater itself? I haven't seen one quite like that...'course I haven't really looked yet either. Would be a great supplement to my sump heater! ...and much safer than my current setup that I don't leave unattended for more than a few minutes...
It works, but I like yours better!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 12-23-2010, 06:03 PM
Chad, what don't you like about your setup? If you're worried about stuff dripping down onto/into the heater, why not fab something so you can blow the air into one of the front cowl inlets with the heater out from under the airplane? Put a foam plug in the other inlet and you're golden..
I woudn't worry at all about leaving a $25 ceramic heater running in my hangar unless it was too close to flammables...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
