Old 12-22-2010, 05:57 AM
flyindoorman flyindoorman is offline
Default Primer overspray on windows
Gave the plane a bath yesterday and noticed several spots of primer overspray on the windows. What is the best way to remove the primer without damage to the glass ?
Randy
N38DG RV7
N204GS RV10 Traded
N63AZ Harmon Rocket II Purchased and flyingSold
N433RV sold
RV10
Dues paid 2020
Old 12-22-2010, 06:05 AM
Steve -7's Avatar
Steve -7 Steve -7 is offline
Default simple solution
An auto detailing clay bar is used for this purpose on paint finishes. It should remove the overspray without scratching the windows. A light plastic polishing might be needed if the window does not come out perfectly clear.
Steve
2016 Dues Paid
RV7 Empenage and Wings
Old 12-22-2010, 05:49 PM
bgaston bgaston is offline
Default Overspray Remover
I had the same problem. Someone in an adjacent hangar painted their airplane and I discovered overspray on my windscreen. "Permatex Plastic Cleaner" Item # 80183 / 403-D worked well for me. I purchased it from Aircraft Spruce.
Old 12-23-2010, 06:25 AM
N223JH N223JH is offline
Default overspray
I've had good luck with Arm & Hammer toothpaste and a very soft-bristled brush on small areas of overspray. Try anything you choose on an inconspicuous area first.
Jim at Bulverde
RV12 N233TX
Old 12-23-2010, 06:48 AM
The Permatex, I mentioned, seems to have a solvent and polish formula.
Worked great for me.
Old 12-23-2010, 06:59 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
For small spots I've had good luck with using a small (about 1 inch) piece of scrap plexi as a scraper. File down one edge at a slight angle to sharpen it, and use like you would a razor blade. Done carefully it won't scratch the canopy.
Alan Carroll
RV-8 N12AC
Old 12-23-2010, 08:40 AM
Default Thanks
Thanks for the replies after the holidays are over I will try and get it removed. It is thin but covers a few large areas that is only noticed when the sun hits it just the wrong way...Merry Christmas
Randy
N38DG RV7
N204GS RV10 Traded
N433RV sold
RV10
Dues paid 2020
