12-20-2010, 03:15 PM
IO-375 Pros/Cons
Hey guys, I wanted to ask thoughts about pros/cons of the 375 from Aerosport. Any recent updates from those flying with specifics, there should be a few of you out there.
My understanding is this is a 360 with a longer stroke providing more than the 180 hp, you can get 195 or 205 depending on the compression. Also, no roller tappets on this one. Same size/shape mounts, uses same prop etc..
So what does this mean to the engine and TBO? Same amount of Metal producing 15-25 more hp ?
I would assume more friction in general due to the loner stroke.. Which means more heat and more wear right? Also, you have a heavier crank that is turning since you have longer stroke. What does all this mean?
Pardon my ignorance but I am at the early stages of looking at engines and wanted to get thoughts or feedback from owners.
Thx
Chad
Sammamish, WA
RV-7 Standard Build - Tip UP
Flying ! As of 032913
Superior IO-375, WW200RV, Single Lightspeed, SkyView, GTN
http://www.704ch.com/
Reason: clarification
12-20-2010, 03:45 PM
I ordered a IO-375 at Osh Kosh this year....can't comment on its operation yet.
FYI - I ordered mine with Lycoming cylindars and roller tappets.... I think the up charge was around $2k.
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
12-20-2010, 09:38 PM
I have one
I only have about 30 hrs. on a 0-375 with 205 HP in a 7A. Aero-sport, you won't find better folks to deal with. 3 blade Catto turns what Craig said it would.
I'm still tweaking the airframe, have the wheel pants and fairings on. I'm seeing about 210 MPH wide open now at 1000' AGL. (Afraid of heights) I think someone with a cleaner and straighter air frame would see even more. Engine runs great, oil temps a little high at first, but now about 180-210 depending on OAT, CHT about 330-340
I really like mine. I was flying a 9A with a 0-320 that I built 9 years and 900 hrs. ago. The biggest shock for me was the increased fuel flow. (What is that old saying, how fast can you afford to go?)
Larry
12-20-2010, 09:41 PM
Fly high....save fuel
12-20-2010, 09:54 PM
Fuel Flow
How much fuel does it burn at, 65% or 75% running ROP?
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
12-21-2010, 06:46 AM
Don't know
I have two 10" skyviews, but I don't have the red cube yet to measure fuel flow. I've never had a plane before with EGT and CHT, so I haven't started experimenting with the correct % of power yet. Before I just pulled the mixture until it started running rough and slowed up a little , then pushed it back in a little. (I'm from the stone age)
Jason is correct about the roller tappets. Bart said that I could upgrade to the roller tappets but I didn't.
Larry
12-22-2010, 03:48 PM
I'm flying one...
The IO-375-M1S from Bart and Sue at Aero Sport is one of the best decisions I made on the entire airplane! Smooth as glass and just over 200 HP with 8.0:1 pistons. (yes that's right, 8.0:1) I'm running horizontal induction with the Superior cold air sump and dual P-Mags.
The speed box average for my -7 at 8500 is 184.75 kts. (Whirlwind 200RV prop) That's 212.46 mph in case you don't have a calculator handy.
Aside from the fact that the engine performs GREAT, Aero Sport could not be better to work with! They are always there to help and are just super people!
The real question: If I build another one, would I buy the same engine?
Answer: Without even thinking about it!!!
- Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
12-22-2010, 03:54 PM
You just needed the power to haul that panel around!!!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
12-22-2010, 03:56 PM
Weight
Peter,
What do you figure on for the weight, with accessories, of the engine?
Thanks!
12-22-2010, 09:35 PM
...and your question is?!?
Yeah I saved weight where I could so the panel could weigh a bit more than average. My empty was 1133. I'll take it based on everything that ended up in this bird.
- Peter
Peter Fruehling
RV-4 - Sold
RV-7 - Sold
