Old 12-20-2010, 11:55 AM
Flying Scotsman Flying Scotsman is offline
Default FF Fuel hoses
I did a search, but couldn't really find a good thread that summarized the info...
I need to replace one of the fuel lines on the engine, to insert the Red Cube into it. Thus, I need to order two new, shorter hoses. Fair enough and easily done, but...
Good God, there are a lot of options for hoses! So what's the scoop on what's used for what? I see, just from ACS,
Aeroquip 303
Aeroquip 666
Aeroquip 601
Aeroquip 466
Stratoflex 124
Stratoflex 125
Stratoflex 156
AAAAARRRRGHHH! I'm sure I'll get as many opinions on what to use as the list I just made here, but thought it'd be worth asking . What's "the right" hose for something like fuel injection servo to spider?
TIA...and hopefully, I didn't start a flame war
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 12-20-2010, 12:20 PM
Default you are--
going to get many differnent opinions, Steve! For what my 2 cents are worth, short runs of 303 hose are fairly stiff. If you have a 6 inch assembly, then you really have only about 2.75 inches of free hose for movement. Teflon is alittle more flexible, but more costly, especially 124, 666, or 466 hose. I guess what I'm saying is it depends on your application.
Tom
Ridgeland, SC
Old 12-20-2010, 07:55 PM
sbarger24's Avatar
sbarger24 sbarger24 is offline
Default Also installing fuel flow sensor
Hey Steve,
Needing to do the exact same thing, and had been dreading it as there seemed to be a lot of choices out there. I had meant these guys at the Reno Air races www.aircrafthose.com, so I gave them a call this morning. Very knowledgeable people told them I needed two fuel hoses, he asked the lengths, and told me I need this type of hose and these kinds of fittings and I should see everything in a few days. Done!
Don?t do what I did the first time and install the fuel flow sensor to close to the electric fuel pump!
Steve Barger
RV-7A slider
Aerosport Power O-360
My RV was born in Reno, but now lives in Grand Island Nebraska
Phase I completed, enjoying Phase II
Old 12-20-2010, 08:44 PM
rv9aviator rv9aviator is offline
What was the problem you had with the fuel flow sensor being close to the pump? Is this a fuel injected or carb?
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 12-20-2010, 08:51 PM
sbarger24's Avatar
It would read 2 to 4 gallons more per hour with the electric fuel pump on. I had it just on the other side of the gascelator, so my other problem may have been that I didn't have enough straight fuel line before it. Though it was quite accurate on long flights that I didn't use the fuel pump much, and you would see an obvious 2 to 4 gallons more per hour when you turned on the electric fuel pump. Its a carb setup
Steve Barger
RV-7A slider
