12-20-2010, 10:19 AM
Drag video
Ever wonder why the fairings on gear legs are so important? An interesting old video about drag illustrates dramatically:
http://www.youtube.com/watch?v=ftq8jTQ8ANE
cheers,
greg
Greg Arehart
N 7965A
12-20-2010, 10:33 AM
Senior Curmudgeon
Cool!!
We all "know" about drag, but it is pretty amazing to actually see it in action.
Thanks, Merry Christmas.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Video
Thanks Greg for the link. I knew that the fairings made a difference but didn't know it was that much (the same round cross section 9.3 times as high as the aerodynamic fairing)
Good info!!
Venice, Fl
12-20-2010, 10:42 AM
VAF Moderator / Line Boy
It says a lot about streamlined antennas versus simple wire rods, doesn't it? It might seem funny that a much larger blade transponder antenna is better than the tiny little ball-bearing on a rod, but it's true! Which reminds me, I need to order some antennas for the -3...where's that link to Delta Pop again?
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
12-20-2010, 10:46 AM
WOW! that is a great demonstration
12-20-2010, 10:52 AM
Senior Curmudgeon
http://www.deltapopaviation.com/Delt...tion/Home.html
Merry Christmas
Mike Starkey
VAF 909
Rv-10, N210LM.
12-20-2010, 11:01 AM
As if I did not know that I needed to get my gear leg fairings on!! Wow! What an eye opening demonstration!
Thanks, Greg!
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
12-20-2010, 02:17 PM
Shape and Flow
Originally Posted by Greg Arehart
That video is one of the experiments Shapiro presents in this book:
Shape and Flow: The Fluid Dynamics of Drag
http://www.amazon.com/Shape-Flow-Flu.../dp/B0007J6AA8
Alex Roup
RV-12 (empennage) #120407
Northern VA
12-20-2010, 02:33 PM
Round is bad....
So would it effect my bent-belly comm antenna performance if I built a fiberglass fairing around it with micro-bead?
Clean and scuff than with some thick fiberglass mold a small fairing around the rod.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
12-20-2010, 03:08 PM
Kent,
Makes sense to me you would lose some drag. I built a homemade pitot/AOA probe out of 1/4" Al tubing and made a similar epoxy fairing around it. Gained two knots (in case Bob Axsom is reading....  ). I'm considering whether to replace my transponder antenna....
cheers,
greg
Greg Arehart
N 7965A
