Go Back   VAF Forums > Model Specific > RV-9/9A
  #31
Old 12-21-2010, 04:03 PM
RV6_flyer's Avatar
Originally Posted by John Clark View Post
Although I will not argue the practice in an RV, I am one of those CFIs that will "slap" you in a retractable of any kind. Way too many embarrassing moments involving inappropriate gear retractions on the ground. The rule at my airline was that nothing was touched until you were clear of the runway, not even light switches.
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Originally Posted by Mel View Post
The landing gear switch on my RV-6 (Yes, I have one) is on the upper left of the instrument panel. My flap switch (the very long one as on the original RV-6) is between the seats. Not much danger of confusing the two.
Originally Posted by rjcthree View Post
Do you call down and welded on final?
Rick 90432
I USE to do what most of the others do. Was flying with a CFI that slapped my hand when I touched the flaps in my RV-6 because of it being a bad habit in a retract. I now NEVER touch anything till clear of the runway (except for opening the canopy on a HOT South West Summer day)
Mel is not the only guy that has a switch like that in a fixed gear airplane. I helped designed what Mel is talking about minus the horn to keep a friend in the habit for retracts. I gave him LEDs, resistors, switch, 9-volt battery clip, and Velcro to attach it to the airplane.
Yes I do call DOWN AND WELDED in the pattern. Boost pump, Gas, Undercarriage, Mixture, Prop (on short final)
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 12-21-2010, 04:32 PM
m3tt5 m3tt5 is offline
What should I do? I am keeping my RV6A at home on my grass strip that is 1600' or so and I alway's have left my flap's down after touch down. From what I have been reading here I should put them up as soon as I touch the grass? That will not make my roll out longer on landing but shorter? I do have manual flaps and it seem's like as soon as I touch the grass I slow down pretty fast. I just started landing here at home this fall so I am new to this short field stuff. So I fell like I am doing pretty good but I keep telling myself it will be different in the summer with less lift.
Old 12-21-2010, 05:17 PM
John Clark's Avatar
John Clark John Clark is offline
Default Don't change
The theory being expressed is that by raising the flaps, and killing some lift, you put more weight on the wheels. Which, on pavement, could be a factor. On grass, the "traction' is low to nonexistent (wet grass) but the trade out is the drag from the grass itself helps slow the airplane.
John Clark ATP, CFI
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 12-21-2010, 10:09 PM
Snowflake's Avatar
If you're making good landings on your grass strip now, don't worry about it, and don't change what works. But if you find (as I do) that slight bumps in the grass strip are enough to put you back in the pattern, you'll find that selecting flaps up as soon as you're established on the ground will keep you there.
Note: Don't select flaps up to try and fix a bad bounce... It'll just make the next one worse. Fix the bounce first, then when you're down smoothly bring the flaps up.
Rob Prior
Old 12-21-2010, 10:36 PM
the_other_dougreeves the_other_dougreeves is offline
Considering I will probably never fly a RG airplane and raising the gear in a RG glider takes a LOT of work (swap flying hands, twist hard to unlock gear lever, pull gear up), I will happily continue to dump the flaps on landing when needed.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 12-21-2010, 10:37 PM
John Clark's Avatar
Default Bounce
If the bump puts you "back in the pattern," you might want to rethink your approach speed.
John Clark ATP, CFI
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 12-22-2010, 12:07 AM
Snowflake's Avatar
I agree, and i'm working it down as time passes. My home circuit has a very tight turn on one end, and i'm leery of taking that too slow right now... I don't mind admitting that I need the extra margin because i'm not that good yet.
Rob Prior
Old 12-22-2010, 08:34 AM
Sam Buchanan's Avatar
been here awhile
Rob,
Here is something that will give you a lot of confidence and safety when flying the tight, slow pattern:
http://thervjournal.com/liftreserve.htm
This is a great way to reduce approach speed while insuring a margin of safety.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-22-2010, 10:39 AM
Steve Steve is offline
I land my 9A with full flaps and leave them fully extended for parking and tiedown. I use 10 degrees of flaps for takeoff. At the slow speed the 9s land, I don't feel raising the flaps to increase brake effectiveness is a concern.
Keeping the flaps down:
1. reduces the number of cycles on the flap motor
2. makes boarding the a/c much easier
Five Sierra Fox
RV-9A
Utah
Old 12-22-2010, 12:17 PM
Default It's all about approach and touch down speed....
I am a disciple of any type of AOA device for safe pattern work.
If the indicator is moving toward the no-fly zone I know more speed will be needed soon, the back pressure relaxed a bit in the turn and/or add power. It is the cats meow for making a minimum speed approach.
A few days ago it was 59 KIAS (well inside green AOA) across some tall trees and right on down to the flare point. Landed and made a turn off in 1500' minus about 600' to clear the trees and flare with very little braking. That will work only if touch down is at or near the 51 knot stall speed of my machine. No time to retract the flaps as they are electric so they stay at 40.
Most of the time I can't do it that short because of turbulence and/or cross wind, but once in a while in really smooth air, it is fun.
(All compliments of Dynon D10-A AOA)
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
