Originally Posted by Walt
#10 = 3/16" = .1875
#12 = .1890
For your particular application you should be fine. I like to use proseal when installing CB weights, helps fill the voids and makes the attachment bulletproof.
No, an AN3 is not 3/16, it is 10-32 threaded, almost 3/16 but not quite.
The shank diameter of an AN3 bolt is 0.186 to 0.189 inches.
You #12 drill is just the correct size at the high end of the tolerance range....
added
Just for clarification, a #10 bit is 0.1935 inches, a pretty loose fit for an AN3 bolt.
